Good evening guys,
Well both PA teams won in the NFL playoffs. So far so good. sure would be nice to have an all PA superbowl.
Jeffrey, where did you get the interior images that you printed?
I asked this question on another forum, but will try again here. When laying HO flex track, does it matter or is it easier to lay the track on curves with the movable rail on the inside or outside on curves?
Have a good week,
John,
Having worked in HO and N for 40+ years, and now due to galloping decrepitude Lionel O. I never gave much thought to this question, but this sums up my track laying practice. Assuming that you are laying the track to its finished position? the outer rail will always pull back from the chairs, I therefore clamp this in position at the connection to the previously laid section, it will then slide out of the chairs downstream as you pull and pin the curve, with the aid of a cutting jig and razor saw cut back the longer inner rail, clean up the end and continue. I also used 'Tracketta' templates.
Hope this helps.:killer:
