Krzychu's USS Skipjack ( SSN 585 )
Dragos
415
Romania
I'm starting to build a new model , a submarine. It's the Krzychu's USS Skipjack , as you know the model is available on his site http://www.mikromodele.cba.pl/mikromodele.htm
The original scale is 1:400 , but I don't like small models so I have print it on a 250 g/m2 A3 paper sheet, so it is with 41% bigger.
Dragos,
I built this one down to 1/700 awhile back. Did you also download the improved nose section from his site? The original proved to be to blunt nosed. Will be interesting to see how this shapes up on the larger end of the scale!
Ray
Dragos,
Ray
Yes , I've used the improved nose sections and they are looking good.
looks really good can you help me out tho what correction sheet did you use for the nose as there are two pdfs i the corrections could you post a pic as to what parts you used :thumb:thnaks for sharing this with us :)
I've used the version with 3 pieces ( the Elips_01_02_03 file) . I will post pictures after I will advance with the construction.
col. kurtz, if You want to see the finale shape of the other Pdf, You can see it at this thread where I choose to use the parabolic one.
Dragos I'm proud to see that someone appreciates my work and my compliments for the fine build.
Best, Nando :thumb:
PS: Kurtz, I don't agree with your opinion in another thread and the truth about Apollo 11...
Hello Dragos!
I observ your re from the beginning. I am pleased very much, that you glued this model. Looks great! :thumb:
Of course special thanks for Nando for making available corrected parts. :)
Best regards.
Krzychu74
I've enjoyed a lot to build this model , Krzychu74 did a great job , also Nando's corrected parts transformed this submarine into a fantastic model.
