Wow!!! Love it!I attached the wheels. Unfortunately, I did not detail the wheels (If I build this again, I will detail out the wheels).
Here is a video showing that the wheels spin (even though the fitting is rather tight) and that the front fork rotates.
Wow!!Here is a comparison between the two Buggies. The one on the left is the "AS-IS" version. The one on the right is the "GREEBLED" version.
Here are "close-up" shots of the buggy.
Thank you for the kind words and encouragement.Wow!!! Love it!Always great to add mechanical motion to these models. It really brings them to life!
Genet Models were one of the first models I built when first starting out (years ago now) due to the simplicity and clear instructions. Great seeing that you are tackling these projects with you great skill set. They also came with some neat dioramas that you can mix and match with other models.![]()
Thank you sir. With the current one that I am working on now, I will be making the weapons pod turret move as well.Wow!!You have really made this model come to life!!
I especially love the rotating turrets. The wheel construction is quite well done. Amazing simply amazing!
