Sandtrooper, 1:16, Julius Perdana design
snake7
503
1,580
48
Israel
Hello everyone,
I’m taking a short break from the armor section again ;)
As usual, this is my “rest” model — and this time also a test build in terms of paper and print. It’s the first time in quite a while that I’ve printed model templates at home.
I printed everything on a Canon printer using Canon Photo Paper Matte (170 gsm).
After printing, I coated all the pages with Americana varnish to protect the surface.
For this project, I chose a relatively simple free model of a Sandtrooper from the Star Wars universe — my second favorite subject after WWII armor :)
Julius Perdana from Paper Replika has designed some excellent models in this theme.
I’ve already built his Scout Trooper on a 74-Z Speeder Bike in 1:12 scale.
This model was originally in 1:6 scale, so I downscaled it to 1:16 to match my collection.
This particular Sandtrooper (also known as a Desert Stormtrooper) is a squad leader, identified by the orange shoulder pauldron. He is equipped with an SD-48 survival backpack and a T-21 light repeating blaster.
By downscaling, I slightly increased the difficulty, but so far everything has been manageable in terms of part size and paper thickness.
If you’re interested, you can read more about this trooper here: here
Originally, the model consists of 12 template pages. I managed to fit two pages onto a single A4 sheet, so in total I ended up with 6 pages.
The instructions are very simple and are provided only as images on the Paper Replika website.
I started with the shoes and the base.
The base was laminated on 1.5 mm cardboard for added strength.
Cool stuff! It's always fascinating to see how Julius managed to translate organic shapes into paper in such an elegant way. The Biker Scout is bigger than it is supposed to be, so I'm very curious to see if the scale is right on this one. :)
What you mean, bigger than it is supposed to be?
On site it is stated that the scale is 1:12.
After downscaling, I tried to compare by boots and relatively they are the same size.
Reactions: mijob
What's stated on a kit is not necessary correct. I printed and assembled the Speeder Bike and the Scout Trooper and both came out much bigger than they were supposed to be:
At 1/12 the trooper should be as tall as the figure.
Shunichi's big R2-D2 kit is stated as 1/6 even though it is 1/8 in reality. This led to major confusion when I started the R5 project and some careful measuring. @Rhaven Blaack rescaled the pattern to produce a 1/32 but since the real scale was smaller it turned out at about 1/48.
So if the finished trooper is taller than 11cm the scale is incorrect.
