GENET Tabletop gaming model collection
13,949
12,472
Arkansas
www.deviantart.com
Hello Ladies and gentlemen,
It is time for a new project. Several years ago, someone decided to make several models (in 28mm/1:60 scale, which are specifically for "TABLETOP GAMING) that both resembled and represented a few different TV & movie franchises. Some of these franchises are "Battlestar Galactica, ALIENS. HALO, STARSHIP TROOPERS, TRON, ETC. The person that I am referring to is Christopher Roe, the owner of the website: https://www.genetmodels.com/
When I for saw these models, I thought that they were quite interesting. Granted, they are a very close representation of the of the vehicles and equipment of the franchise they represent. However, these models (for their size and scale) are quite details. These models are (for the most part) easy to assemble and easily lend themselves to potential greebling.
I have decided to build a few of these models to both demonstrate ease of the assembly and how to greeble them out to the fullest extent of the model. Each of the models that I will be building, I will build twice; once "as-is" (per the template and instrustructions), and once greebled out to the fullest extent (to include, but not limited to moving parts).
I am starting off with the "CHAPARRAL RECON BIKE" (Yes, this is the "TRON" LIGHT CYCLE clone).
Yes, there are eight different colours to choose from.
I chose to build the "white" bike. Here is how the whole parts sheet looks like. As you can see, the parts sheet contains the parts to build two bikes.
I cut one set of parts for this build.
The body is assembled.
The rear fork is assembled.
The rear fork is attached.
This is the front fork.
The front fork is attached.
The wheels are assembled.
The wheels are attached.
The colling vents are assembled.
The cooling vents are attached.
The gun pods (optional) are assembled.
The gun pods (optional) are attached.
This was a very simple "DAY" build.
I will rebuild this with greebling.
I would have cut the wheels round, instead of the flats like that, but it looks great! :)
It is now time for the greebled version. Since the "AS-IS" version showed the details of the actual build, this will show more of the greebling.
Starting with the body and the front and rear forks.
The body is assembled and the pivot post for the front fork is attached,
The front fork is assembled.
As you can see, I punched holes for the pivot and the wheel axle. I raised the panes on the forks.
The front fork is attached in place. I started adding the greebling panels to the body.
The rear fork is assembled. I raided the greeling panels.
I attached the wheels. Unfortunately, I did not detail the wheels (If I build this again, I will detail out the wheels).
Here is a video showing that the wheels spin (even though the fitting is rather tight) and that the front fork rotates.
View attachment 20260410_162533.mp4
Here is the next GENET project: "JACKRABBIT BUGGY"
Here is the parts sheet.
The fenders are assembled.
The fenders are attached in place.
The axel shrouds are assembled.
The axel shrouds are attached in place.
The wheels are attached in place.
If you are wanting a "civilian" (unarmed) version, this model is now done.
If you are wanting the "MILITARY" (armed) version, please continue watching.
If you are still watching this section of the thread, here is the weapons system.
The turret base is assembled.
The turret base is attached in place.
This is the pod swivel.
The pod swivel is attached in place.
The pod rotator is is assembled.
The pod rotator is attached in place.
These are the pod yoke, pod rack and missile pods.
The missile pods are attached to the pod yoke and the pod yoke is attached to the pod rotator.
The pod rack is attached in place.
The simple JACKRABBIT BUGGY is done.
"AS-IS", this model is a simple ("DAY") build.
Now, on to building the "GREEBLED" version.
