U.S.S. RELIANT NCC-1864
13,817
12,269
Arkansas
www.deviantart.com
When I first started (scratch) building models, the very first Starfleet starship that I built was the U.S.S RELIANT. So when a template of the Reliant became available (and yes, there are a few different ones available), I (very quickly) downloaded the one that was designed by @Rawen. I have been wanting to build this model for quite some time.
*NOTE* Granted, this template has a great deal of greebling potential. However, since this is the first time that I am building this model, I will be building this model "AS-IS" (no greebling).
There are 10 sheets of parts in A-4 format. I originally printed the template on letter format cardstock. Unfortunately, I was not able to have everything printed properly. So, I printed the template at 95%.
Here are the parts sheets.
I started with the top skins of the saucer section.
*NOTE* Whilst working o the saucer section, it is needed to add glue strips to connect some of the parts.
*NOTE* When assembling the skin, the builder need to pay close attention to the printed textures and make certain that all of the lines are mated up properly.
The top skin for the saucer is assembled.
I added more strips to reinforced the center piece of the skin and I attached the edge ring.
The template requests that the builder laminates a disc (that is included with the template) to 4mm-5mm.
I attached the disc in place.
Please stay tune to your local "GLOBAL NETWORK BROADCASTING SYSTEM" for the latest updates on this project!
Here are the PHASER banks.
The PHASER banks are attached in place.
Here are the parts for the skins of the underside of the saucer section.
I started to assemble the skin. I added strip to help with assembling the rings for the skin.
The skin is assembled.
I attached the skin to the edge ring.
Again, pay close attention to the textures and line everything up properly.
Now for the sensor array dome assembly.
As I build the individual components, I am attach each component in place.
I added the PHASER banks to the underside as well.
One, if not, my favorite Star Trek ship. This ship looks robust, and made to fight. No long nacelles sticking way up on pylons, this ship is a brute. It would work in any SciFi show as far as I am concerned. Great choice. :)
Originally the nacelles were supposed to be facing upwards but due to a slight communications error the design was changed: The plans were accidentally presented upside down! The producers liked that and so they kept it. :)
Great step-by-step build thread!
Great work too...
Thank you sir.
I have to say that the template has a great deal of greebling potential. So, I encourage greebling this model out to the fullest extent. Unfortunately, I will not be greebling out this build. (Eventually) I will be rebuilding this model (in the future), and yes, I will greeble it out.
