"V" - Visitor blaster (2.0)
13,881
12,362
Arkansas
www.deviantart.com
Back in 2012, @Revell-Fan designed a FANTASTIC paper/cardstock model template of the blaster from "V": The Series. Here is the link: https://www.zealotmodels.com/threads/v-visitor-blaster.172340/
Recently, @Revell-Fan and I decided that the template needs an upgrade. The new upgrade is a "functioning" trigger.
The (general, over all) build is straightforward and (fairly) easy.
Here are the parts sheets (11 sheets in total).
Here are the parts for the front main body (and indicator switch, which does move back and forth).
The indicator switch is attached to the front main body.
Yes, the indicator switch does move (back and forth).
Here is the back side of the front main body.
Starting to assemble the front main body.
The formers are assembled and ready to be placed into the "skin" of the front main body.
The former are put in place.
The front main body is fully assembled.
Showing that the indicator switch can move.
So please stay tuned to the "FREEDOM NETWORK BROADCASTING SYSTEM" for the latest updates on this project!
Here is the heat sink for the barrel.
The body of the heat sink is assembled and the strips for the heat sink are laminated to 1mm (and the edges are painted black).
The heat sink is fully assembled.
*NOTE* When rolling the strips, the strips will (more than likely) delaminate. It is an easy fix. Just glue everything back together. Then apply the strip in place.
The heat sink is attached in place.
Here are the parts for the upper receiver.
The main body of the upper receiver is (partially) assembled. As you can see, the recessed component is in place.
Here is a close up shot of the recessed component.
(I recessed the grey shapes in the recessed components.
Here are the internal formers and the (mostly) assembled upper receiver.
The formers are in place.
The upper receiver is assembled.
After quite a bit of work (and a few rebuilds), @Revell-Fan and I finalized the framework for the handle (and (working) trigger system).
I started with framework for the handle. Here are the parts. All of the formers are laminated to 1mm thiuck (with the exception of 32a, 32h, & and 32i which are left at 0.22mm thick).
These are the formers for the (main part) of the handle.
*NOTE* When assembling the formers, the formers need to be canted (angled), to be glued in place.
The formers are glued in place
Here are additional formers (for the trigger assembly well and strut well).
The formers are glued in place.
Moving on to the lower strut.
Here are the parts for the strut. The formers are laminated to 1mm thick.
The formers are assembled and the skin is pre-formed.
Starting to assembled the strut.
The strut is fully assembled
I test fit the strut.
Here are the parts for the skin of the handle.
The skin is assembled.
Here are both the skin and framework.
I placed the framework inside the handle skin.
Moving on to the trigger system. @Revell-Fan and I decided to use the same "paper" spring (that was used for the buttons of the LANGUATRON (and COMPUTRON) from Battlestar Galactica (and Buck Rogers in the 25th Century).) for the trigger system.
I attached the "trigger-stop" supports (so that the trigger will stay in place)..
Here are parts for the trigger and spring.
The former for the trigger is assembled.
Starting to assemble the trigger.
The trigger is fully assembled.
Here is the trigger and trigger plate.
Starting to assemble the spring.
The spring is assembled.
Here is the insertion of the trigger assembly.
slide the trigger through the (front of the) hole.
Glue the trigger plate to the back fo the trigger.
Glue one end of the spring to the trigger plate and the other end to the back of the trigger assembly well.
I inserted the strut in place and attached the internal framework plate.
I attached the side skin.
This is the part for the trigger guard.
The trigger guard is assembled.
The trigger guard is glued in place.
This video shows the functionality of the trigger.
View attachment 20260303_222936.mp4
Excellent! Developing this trigger system was some hard work. RB had to rebuild the handle several times until everything fit properly. In addition, the new skeleton makes the gun rock-stable. Now that we have the data we will adapt and re-use the trigger system on future blaster models. I'm revising the instructions on-the-fly. Stay tuned! :)
Even though I had to rebuild the handle system several times, it was well worth the time, effort, and work. I am very pleased with the outcome. I am glad that we can implement this technique to other projects.
Reactions: Revell-Fan
Here are the textured grips.
I made another copy of the texture grips. One set is laminated to 1.0mm and the other is laminated to 0.5mm (for the "ribbed texture).
The base part of the grips are laminated to 2.5mm.
The textured grip is assembled.
The textured part is applied to the base.
The grip was attached in place.
Here is the receiver and handle.
I have mounted the receiver to the handle.
Here are the components for the front of the receiver.
The components are attached to the front of the receiver.
Here is the front of the receiver.
Here is the part and former for the front handle.
The skin and formers are assembled.
The handle is assembled.
Here are the parts for the connectors for the front handle.
The connectors are assembled.
Assembling and attaching the connectors to the handle.
The handle is fully assembled.
THe handle is attached to to the forward stock.
This is the energy tube connecter for the front stock.
The connecter is is assembled.
The connecter is attached.
The main parts of the pistol are assembled.
