ALIENS..."this time its two!"
Chuffy70
1,218
2,574
Norwich UK
With the Razor Crest recently built, its time for another couple of quickies (I hope!)
I'll build these two together, and see if I can improve on the Dropship
This variant from the same stable was built many years back, and never really finished the paint job/seam coverage.
Was made from thick cardstock, which really hampered the build.
As I progress with the other two, I'll see about patching this Dropship up to look a little bit better.
Although you can't really see this gaping void, I will attend to the 'hole'
THANKS FOR WATCHING... "Stay frosty!"
In this episode Adam presents the original filming miniature of the Surface Seeker. The video is really worth checking out because you will not get any views at the model better than those. You can use them to flesh out the papercraft. My idea was to take screenshots, put them onto the papercraft and make a photorealistic texture. I put the idea on the back burner because Jan's model already has an awesome texture and (of course) I don't have the time for it now. ;)
Cheers for the link, I do love a bit of Adam looking at props.
Not caught up with this one yet, but I will give it a look at some point, much appreciated for the content info.
Much like yourself, time is my arch enemy, so these will be very quick builds with no mods whatsoever, other than paint.
Nice work it looks very 3C
Loving a 3C from thee, unlike these, blown up, the edges are very un-clear
You are off to a good start with this project!
You say all the right words...
Moving along... Parts for the front and side skirts.
Easy enough...
Bit fiddly with all the angles, but got there in the end.
Last parts, wheels and axles.
Cut, curled and creased...
Fuzziness around the wheels made these fairly trickier than they needed to be, but all good.
All sub-assemblies are now ready for final construction...
I see that this model has quite a bit of greebling potential.
I think every model you see has 'that' potential ;) Sadly not on this build
Are you making your own dumbels from paper. That's not what I call weight lifting.
Though they are looking great as the rest of your parts.
Indeed they are at this very moment being employed for weight lifting trials - SEE PICS
He is the current paperweight champion.
:animated:
Me? Nah, I'll leave it up to these two... ;)
I think the 'weight' is an often over-looked tool to assist on the model-bench.
A few favourites, other than a good book, are my newly acquired engineering blocks, the helping hand with is cast base, a mini dumbbell, two £5 coins (only legal tender on the island of Jersey!) and what I'm presuming to be a lead button I found... doesn't look much, but as buttons go "its weighty!" just enough to keep things in the right direction.
The Seeker is now waiting in the wings, ready for paint.
Attention now turns to the Dropship.
Parts selected for the front section...
Cut, creased and ready for action...
There's a LOT going on at the front of the Dropship, and even though I know what this craft looks like, over-familiarity can lead to mistakes.
I decided to make sure all the singular pieces here where at the stage they needed to be before dry fitting every part.
A few more parts were needed to help guide my edges and locations.
"Chaos" well sort of... lots of sub-assemblies dotted about ready for coming together.
One thing to keep track of when building this model is the part number and the tab locations.
Some parts have them and others do not - thus I made sure all numbers and tabs were labelled before construction.
Front main mid-section successfully married to the mid-cargo hold.
Didn't get this right on the first build, just shows that using a suitable cardstock really pays off.
Forward section nearing completion on the upper.
The frontal air intakes were becoming annoying, despite me labelling everything, they just weren't playing ball.
The thing here was me noticing the inboard front, compared to the wing side was slightly larger, so I went with that, I not fussed here as to whether they are the right way round or not, I just wanted a decent fit.
The front tab and the tiny inner tab on the intakes are also mis-leading if you are not paying attention, further study of the filming miniatures was needed to gather information on how those front intake flaps fit.
Full-size studio prop - probably was 'struck' and skipped after filming :(
In-flight
A big one!
Proof of concept model.
With careful study and arranging the parts in front of me, the brain was re-booted and clarity was had.
Time to fit these buggers!
After wrestling with these intakes, they finally scummed to the fight!
Rear of the front section completed.
Next up will be the main cargo hold.
A little more work on the Dropship.
There could be some repetition here as I'm sure I posted these, so I'm not sure if some got lost in the 'move'
Anyway, the lower front sponsons/doo-dads were next to complete the front section
Incredibly difficult to get right as one part has a rather exaggerated acute angle which pulls in the side pod.
Whilst head scratching on the sponsons, the cargo bay behaved itself and went together almost dream-like
The main body has been set aside whilst work begins on the topside
Just a small update, due to technical issues in getting some photos to load... there could be some 'jumps' in picture construction.
More Dropship nonsense...
Hold/Cargo bay installed, was a bit tricky, but it did line up.
However the flat part between the cockpit and sponsons was not accessible to press on for a tight gluing.
Solution was to jab a large needle through the spots marked 27 & 25 glue the area and hold the needle against the back... sort of worked.
Working backwards to the tail I had managed to skew the inner lip. Luckily this will hidden and painted as well.
Flipped over and looking not too bad, can't wait to add some paint to this
Time for some engines and rear stabilisers.
The curves on Part 39 were a bit floppy and needed beefing up before adding 37.
4 layers of spare card was used to beef these up.
A bit better...
Ready for adding on.
Harrier style vertical thrusters added, or AV-8B to my American followers.
Getting there slowly...
Vertical stabilisers added.
Next on the agenda will be the rear landing leg.
