Thanks I installed it, and hope this works out for me!I use FOXIT .pdf reader, it's free.![]()
Creative use of a cardboard box for sure!Lol!
				I didn't build that, I just admire what the Lego people do with the sci-fi jaundra, I think this was found on photo bucket.That is the first time that I have seen the Romulan Bird of Prey make of LEGOs. You did a GREAT JOB on the project!
That is cool! I used to use those plastic hand pump water rockets when I was a kid. The Red and white ones!I used to launch rockets 100's of feet with water Rockets. You will fill the very thick plastic with water, then pump up the Rockets with a hand pump. The base of the rocket had the intake for the air, and was also the propulsion chamber. Release the tabs, and you would get a 100 vertical feet launch easily.
I do agree, the guy should had added Mentos, but that paper aircraft had the center of gravity so far off, any longer flight, and it would have gone out of control as is seen.
I do have to admit, that was some really seamless building using corrugated cardboard I've seen.
The Lego model is convincing!
Here's a neat bottle rocket using just water.
Very clever design!I used to launch rockets 100's of feet with water Rockets. You will fill the very thick plastic with water, then pump up the Rockets with a hand pump. The base of the rocket had the intake for the air, and was also the propulsion chamber. Release the tabs, and you would get a 100 vertical feet launch easily.
