Chipboard
Potamus
84
249
I want to make Rhino APCs from Warhammer 40K and am considering using chipboard to do so. I could post this in the Warhammer or Armory & Military forums but I want to ask a more general question about chipboard. How is it to work with? What point or thickness should I get for this project in mind? 20pt? 32pt?.. 50pt!?... Is it even worth using this material?
Why would you use chipboard?
I haven't used chipboard yet, but I love to work with grey board. To me 28 pt sounds realy thick mostly I use 1 or 1.5 mm.
I'm wondering this myself. I think I might be able to make sturdier panels for assembly. My alternatives would be printing templates on cardstock alone and glueing two pages together or using corrugated cardboard.
Reactions: mijob
I'm a big fan of cereal boxes and corrugated packaging boxes. You can laminate as many layers as possible and at the same time you are recycling resources because the boxes would go into the trash otherwise. Of course one layer of chipboard may be stronger than one layer of regular card, so I understand what you want to achieve. I for myself have never used chipboard because so far it has not been necessary to get it for my purposes (I have to order everything online). I'd like to see what you can do with it, so I'm not against using it. ;) I'm sure you could reinforce the parts in a way that they become as solid as a brick. :)
IF you use chipboard, I would suggest concentrating on the actual thickness of the material. Go to Harbor Freight and get a good digital caliper (they cost between $20.00 - $40.00 USD).
For me, a caliper is a very valuable tool to have when building paper models (especailly if you are making peices that have to be the same thickness..
Thank you. I'm still considering it. I think I'm going to start by laminating cardstock and build one that way first. I think could build interior struts for reinforcement. If I'm not satisfied I might consider chipboard or corrugated cardboard.
1110 lb. card stock, and 67 lb. card stock, through laminating, should be enough for all your needs. By laminating the 110 lb. stock, and placing that part under a pile of books, the resulting piece will be incredibly solid. :)
Reactions: mijob and Potamus
Did you say 1110 lb?! What is that like a half a foot thick!?
No.... its about the same thickness as playing cards.
I use a product called Ram board. you can get it at the big box stores ( lowes & home depot). It comes in a roll that is 36 inches wide and 50 feet long, and is 1mm thick for about $30.00
Contractors use it like a drop cloth for tile work. it is a dense cardboard.
110 lb. stock is not very thick at all. It has a bit more rigidity than .67 lb. stock. The paper weight is for large amounts. Maybe the charts below will help. Don't forget to round to the closest number! ;)
Thanks Zathros. I've heard that Lbs don't convert as neatly to GSM because it depends on how much material a manufacturer uses to measure the weight of their product, but I see the ratio is 1:1.48. Either way l always like to look for their GSM to be sure. The point system makes a lot more sense looking at this. I understand 1 point is 1/1000th of an inch but thats hard to visualize. One thing I've looked up to help is that 50 points equals 0.05 inches and is about the thickness of an American penny or 1.5 mm.
  • Love
Reactions: micahrogers
You will find that most people use 110ob. stock and 67 lb. stock, and double or mix and double up. I also use very thin note paper stiffened with Dope, or Crazy Glue. That technically makes it a composite part. :)
