Solo Millennium Falcon build thread - greeble learning
ElMäx
153
383
So next comes my fourth model. I really don't know how long I will keep counting. I also don't know how long I'll keep up this pace of posting builds, but it is probably because until now they were "simple" models and I get to know the methods and learning skills. I will probably turn to longer and more complex builds some day and just post when I encounter major problems.
There is that one big detailed model of the millennium falcon, template also in the zealot resources I think. and next year I want to build a nice xwing as birthday present for a friend.
But first a will do that small blue lando falcon from the solo movie (which I did not saw until now). Here I want to try out some greebling and testing out things like plastic for windows and hopefully a varnish in the end.
I started out with stabilizing cardboard sheets for the saucer part and the bow. Just improvised and guessing how to put them. trusting my heart and little bit reasoning:
I then added a second top saucer part where I cut out the places of the six black radiators. Did not take picture but will be seen later. It is the same what @starbuck did here: https://www.zealotmodels.com/thread...ion-of-the-movie-solo-building-thread.180808/
Btw. this build thread in general helped me much. Thank you @starbuck for your detailed and very good thread!
Next the upper turret. Here I wanted to use a small plastic lens, cut out from some stiff packaging, as a glass window.
Then I was thinking, why not cut out the white frame of it from another print, to glue it on top for a really nice 3d greeble look. But the cut out piece was to ragged and destroyed to use. Perhabs later I will try to paint the frame with not thinned white acrylic paint to achieve that effect.
And that leads to the foto which I posted a few days ago in the discussion thread of that model resource. That reflection on the window really shines
With all the cardboard in it, that thing turned out quite stable with much structural integrity. And it is very fun to build.
Since then I already went on with the model. Will post soon
The cockpit.
Here again used that thin but stable board from the back of paper blocks, that can be bend smooth without folds to stablise the corridor to the cockpit.
For the cockpit I used a kind of thick plastic foil for the curved window and that same transparent plastic like for the turret windows on the smallround front window. Then glued an extra cut out layer of the cockpit without the black regions on top to accomplish that recessed window effect. The result is a bit ragged and unclean on the edges:
Used two layers for the bottom saucer part. One to close it and then a thicker (190g paper) to smooth out the terrace-like steps from the cardboard inside. Also had to cut out creative gaps in the middle of the saucer parts to get the curving of the flat paper right without major folds and bumps. Also had to cut in at the back part (where the 3 is indicated) and hope that the cut will be covered up and hidden later with the other parts from the underside of the model
Then I got to the point, where the side parts had to be assembled. These corridor hulls with the escape pods at the ends. The first I reinforced with corrugated board. I think with that model I am all for stabilizing (cause I mostly used 120g paper, quite thin). But in the end I had to leave out the 8 edged board in the middle, it was to thick.
And then I realized that with two saucer sheets each at top and bottom plus the board sheets inside the hull was to thick for the escape pod side corridor. I had to cut the corridor parts in the middle and glue one half on top saucer the other half on bottom saucer.
But it worked out in the end:
Explorations in greeble
I added an additional thick back region of the top saucer and laminated the 6 round radiators to let them pop out.
After that the small round things on the underside of the bow. Don't know if they have to be concave or convex. Mine are convex now.
And then the stowed landing legs. Gave the feet a bit profile.
The in-flight model is almost done. Now I will mostly add smaller details and new cannons. In the @starbuck thread was the idea of adding cut out pieces of the hull plates. I want to try it, but fear to ruin all the work
During the last months I continued to glue the hull plates as separate parts to the hull to achieve a more 3dimensional look. I worked on that sporadically but it is almost finished. There are just some parts still missing.
But one thing I also really wanted to try is to add the landing legs. Make them detachable with small magnets.
I used parts of toothpicks to strengthen the legs and took the magnets from my collection from cigarette paper packs. Collected the magnets over years. Finally I can use them.
These paper packs of course come with a small metal plate for the magnets to stick on. These metal plates I cut into smaller pieces and glued them between the hull and the "retracted" landing gear.
That way there are two layers of 190g paper between magnet and metal plate. Easy to pick up, but still sufficient force to keep the legs on place.
That looks very good! The Gozanti cruiser is on my todo list. When I get to it, I'll put magnets into four Bandai 1/144 TIEs and attach them to the bottom of the ship.
  • Love
Reactions: ElMäx
