Imperial Lambda-class T-4a shuttle TYDIRIUM
Spaceship engines! is there no end to their troublesome awkwardness!!!
Nicely handled, can't wait to get flustered by this one!
Thank you I think at some points the model can be improved. For example the dimensions are too precise there is no room for error. I have ended up with some white tab areas if the designer made the colour areas a bit longer you would not have that problem. The same with the engines it is possible to design it less complex. But still its a great model.
And Im on my way. First Im going to build the part shown in the image below.
First I have glued the parts needed on 1 mm thick cardboard then cut the parts. This is a real blade killer when cutting the curved lines.
To make the holes I used a hole punsher. You can see it in the picture.
Before assembling check the fitting of the parts if needed use a file. If all fits you can assemble the parts.
I used clamps to glue some parts.
One important note some parts are fragile dont worry if they bent you can fix it at a later moment. See the red circles.
This is it for today have a great weekend.
update 16 01 2024.
Before you glue the framework glue the parts as shown below to it. Otherwise its very hard to glue them to the framework.
View attachment 216199View attachment 216200View attachment 216201
i used a wooden dowel through the holes for the wings to pivot on.. easier than rolling the paper..
Smal update working on some interior parts. First the back cabin seats.
Parts cut, scored and perfolded.
First glue the top and the the lower part.
Seat done you can see how smal it is. You need six in total.
I have orderd some optic fibres to see if I can light up this model. The fibres will go in the wing I will use electronics to get flashing lights on the wing tibs. The back cabin will have white and red LED's. And I will try to get the instrument panel alive.
Reminds me of building the tiny little seats in my 2001 Moon Bus, fiddly but worth it... by the looks of things, my seats will be 10mm bigger than yours?
I'd love to start mine and have a 'Shuttle-Off' :) (sadly the Y-Wing is dragging me down!)
I collected my copies of the Shuttle last week, but the copy machine printed them off in a strange colour!!!
Firstly the guy did them in Black & White, to which I said erm, no - I wanted them in colour...
So I have ended up with an odd colour Shuttle one side of the paper and a black & white one on the other side!
The local firm has two machines and various people operating them, so the guy I normally use wasn't there... I think I might have to re-invest in another A3 capable machine...
Beige Shuttle, with Purple highlights?
O boy that doesnt look good indeed. It would be a very colour full model if you would build it. Are you going for the normal sized shutle or did you enlarge it? If so you internal structure needs thicker cardboard.
Luckily the prints were free... otherwise it would've cost me 0ver £20-23 Euros!
Yeah these are A3 sized, so by the looks of the doors and seats, probably about 1/72 ish
Lets start to get some light in the darkness.
First cut, score and prefold. Remove the parts that looks like lights.
Then glue some tin foil do not cover the light cut outs.
Remove the tin foil covering the light cut outs.
Glue transparant paper over the light cut outs and glue the remaining tin foil.
Light check.
And done.Next is to assemble all parts that goes in this cabin.
Also I have removed all the glue tabs for me uts much easier to place the cabin into the frame.
