Moving on to the axles, bogie wheels, and drive wheel sprocket.
Here are the parts for the Bogie wheels.
I assembled the bogie wheels.
After laminating the detail parts for the bogie wheels to 1mm thick, I added them to the wheels.
Moving on to the axles and spacers.
I formed the axles and attached the spacer to one side.
*NOTE* Use a dowel that will fit just inside the the axle to help with putting the axle through the chassis.
I attached the bogie wheels to the axle.
Adding the rest of the axles and bogie wheels.
Next is the drive wheel sprocket.
Here are the parts for the drive wheel sprocket. The main sprocket parts are laminated to 1mm. thick.
Assembling the sprocket is easy. Just laminate the parts together
Add the front plate and "bolts".
Added the "bolts" to the other side.
The drive wheel sprockets are attached.
