Tie Bomber design and building thread
Lets continue. I started drawing the wing supports.
And the pilot fuselage with the front window
And last but not least the bomber fuselage.
At the last page you can see the parts of the rear engine.
So now its time todo some cutting. Please keep a eye on this thread there is more to come. :yesyes:
You are right its indeed the big one I geuss something went wrong with printing the page. U checked the drawings and they are both the same size. I have to take better care when printing.
The size mismatch was not a printer problem the small one was the correct size. The big fuselage was the one I used for the striker. Anyway I think the small one is to small and the big one is to big so I will go for the midle solution. I changed the templates and start again building the fuselage with new parts. This evening its cutting time.
And here is a new update. I rebuild rhe fuselage. Here are the three fuselages side by side.
And here are some close ups of the ion engine.I have used the midle one.
Yust some minor adjustments and I can build the bomber fuselage with fuselage support. Till next update keep save.
Sure you are not building a Saturn V??? ;)
And here you have the first paper binoculars.
:animated:
Oops its a bomber look a like.
Im verry pleased with the first results.
The fuselage support needs some internalforrmers and a glue tab to fit it on the fuselage. Not a big issue to add this in the template. Next will be the wing supports I hope this will go as smooth as with the fuselage.
