ASP7 (Star Wars)
chajal
Active Member
Jan 27, 2005
20
48
Mexico
www.geocities.com
Basado en el juego de PC "Battlegrounds"
Based on the PC game "Battlegrounds"
El "droide" lo pueden descargar de:
Modelos de Starwars
Para imprimir en cartulina tipo opalina Para colorear, recomiendo usar plumones a base de aceite o permanentes, ya que los de base agua deforman el material
The "droid" can be downloaded from:
star wars models
To print on opaline-type cardstock For coloring, I recommend using oil-based or permanent markers, since water-based markers deform the material
¡Empezamos!
Let's start!
Cuello - Neck
Torso
Cuello + Torso Neck+ torso
Cara - Face
Take all of the time that you wish. There is no need to rush through anything. This looks like GREAT model! Thank you very much for sharing your work with us!!!
I am going to have to try my hand at it, once I get a few other projects out of the way.
Reactions: micahrogers
Solo haz clic en la foto del droide
Tiene abajo el siguiente texto
Si deseas descargar el plano en PDF, solo haz clic en la foto de arriba
Just click on the photo of the droid
It has below the following text
If you want to download the plan in PDF, just click on the photo above
No se puede descargar el model. Puedes poner un "link" directamente?
The "Download" link doesn't work, could you put a direct link up? ;)
