I copied the whole structure with the texture. You can easily beef up those strips by adding additional layers. But please keep in mind that this is 1/50. The whole vehicle will fit inside your palm when it is done, so @Rhaven Blaack is doing a phenomenal job with it!!!With the work you put into the wheels, I offer my .02 cents worth. Cut out the boxes in the tracks, and the cross strips should be greebled up by gluing long rectangles on the strips (or stacking strips for the same effect). Those Thiokol tracks were made that way. They actually unbolted for removal and replacement, if they got damaged or dull. That will allow your wheels to b e seen better and give the model a very nice touch. You can see how the wheels were kept on the tracks looking inside and seeing the hard rubber pins that centered the wheels in that grove, and how the "Staar" drive wheel worked by fitting and pushing against the rectangles.
