Colonial Viper Car
13,910
12,409
Arkansas
www.deviantart.com
Hello Ladies and gentlemen,
It is time for another fun project. This time, I am building the Colonial Viper car (designed @Revell-Fan for the 2021 Paper Jams).
If you are interested in trying your had at this model. you can find the template in the RESOURCE SECTION here: https://www.zealotmodels.com/resources/colonial-viper-car.2404/
I am starting with the cockpit interior.
Here are the parts for the cockpit interior.
The seat is assembled.
The tub is assembled.
This is the brace for the dashboard console.
The brace for the dashboard console is attached in place.
The seat is attached in place.
The dashboard console is assembled. I raised the screens.
The dashboard console is attached in place.
The steering will is assembled. I raised the actual handles and the center medallion.
The steering wheel post is attached in place.
The steering wheel is attached in place.
Please stay tunes to your local Colonial Broadcast network for further updates as they come in.
Now, moving on to the nose (front fuselage).
Here are the parts for the nose (front fuselage).
Here is the inner nose piece. I raised the license plate and the head light lenses.
I attached the cockpit tub to the fuselage body and recessed the side steps.
The fuselage is closed. The rear piece and the inner nose piece are attached in place. I also raised the three front orange lights, the cockpit canopy rails and the arch over the steps.
Moving on to the cockpit canopy. Since I want an "open" canopy, I had to work a little magic.
I layered two sets of canopy parts to (2" x 4") shipping labels. Wi the outside of the canopy, make certain that you DO NOT glue the roof of the canopy to the label (*NOTE* I will explain this later.).
I cut the outside layer of the canopy, painted the inside edges of the windows, and attached it to the clear plastic.
Make certain that the roof of the canopy is still not glued to anything.
Here are the inside pieces for the canopy (the inside edges of the windows are painted) and the main part of the canopy.
I carefully attached the inside pieces to the main part of the canopy (making certain that the edges of the windows lineup properly.
I trim away all of the access plastic.
The canopy is formed and the rack and wiper are attached in place.
With the rack, I cut away the void areas and raised the bars. With windscreen wiper, I raised the gray wiper arm (to show depth).
Now for the "tail and wings".
Here are the parts for the "tail and wings".
The "tail and wings" are assembled. I greebled the lights.
Here is the "tail". On both the front and back lights, I raised the gray boarder around the light lens and raised the lens itself.
For lights on the wings, on both the front and back lights, I raised the gray boarder around the light lens and raised the lens itself.
For the side light on the upper rear part of the wing, I raised the black boarder and raised the lens as well.
Now for the "engines". The "engines" are straightforward and easy to build.
Here are the parts for the "engines".
The "engines" are assembled. I raised the all of the greebling, and "domed" the lights.
I attached the wings and tail to the "engines".
Great work, your cockpit canopy is great, transparency for paper models seems to be my downfall.
