Thanks Mijob and Zathros
Additional parts for the engine
Power unit and engine mounts
Now i got exact position of engine mounts on the floor
Air filters with mounts
Tubes from air filter to cylinder were maid from wire with isolation
Errors:
Tube pattern number confused with other tube pattern.
By 251l, 251 they meant 88l, 88p. And vice versa 88.
In addition this pattern was wrong - cylinders on both sides are asymmetrical and there is no chance you can use same pattern for both. Also, connections to cylinders must be vertical and not horizontal, as shown
Errors:
