Star Wars A-Wing from Shunichi Makino with extras
thegreek270
Well-Known Member
Aug 7, 2010
265
670
76
Greece
Hello everybody,
I wanted to share with you my build of Shunichi Makino’s A-Wing
After finishing with Rey’s Speeder, I had to decide what to build next and then I stumbled upon bigpetr’s build. I liked the changes he did on that model and since I had the A-Wing on my TODO List anyway (one of many Star Wars Models) I chose that including changes and greebles.
First, I built the base.
I made two prints, one for the basic box and the second to add another layer on the surface. I reinforced it with card from cereal boxes.
To keep the box stable and in shape I built some right-angled tubes with three surfaces and placed them on each edge.
Then I glued the sides one by one on the card and closed the corners
After the base I started with the cockpit.
I combined Shunichi’s parts 24,25,26,27 to one single box and turned all the graphical elements on the sides to 3D objects.
Thank you guys.
Next I started on the main body
I devided the hull to wings and mainbody, reinforced the mainbody with card from cerealboxes. I changed the templates in that way so I had the wings as one peace.
Unfortunately, I can not show any pictures of that stage. They were lost during transfer :( .
I went a similar way like bigpetr with his build
https://www.zealotmodels.com/threads/star-wars-a-wing-shunichi-makino-heavy-mods-1-48.180415/page-2
First i bent the wings into shape making them a bit wet from the inside so they keep the form. After they where dry i put some cereal card inside with the same form to cut out the black slits. I used some black card shaped in U-form to cover the slits from the inside. After some try's i finally found the right shape and glued it into place.
Then i connected the top and bottomparts at the front and wrapped them over the main body which i made out of cereal card. When everything was ok i finally connected the wings.
This Picture is the only one I could recover. The wings are already finished and atached to the mainbody
Then I build the Engineplate
The canopy
Look, I built myself a hammer :)
For the form I built Sunichi's original canopy and then I formed it using a grinder and sandpaper until the desired shape. After
A quick test
Then I printed out the black canopy parts twice, one normal a bit bigger and one inverted and a bit smaller. I placed the bigger one on the outside and the smaller one on the inside exactly on the same position so now glue is visible.
Some additional greebles
This is a verry nice model it looks amazing.
That canopy is looking awsome :bowdown:
Job welldone thumbsup
Amazing build! The extra details make it really pop. I'm sure this will inspire other builders to make similar enhancements. Thank you for sharing it with us! :)
As for the next build: Shunichi's AT-AT is a very good kit. And rumours have it that someone has developed a not-too-shabby-looking Colonial Viper Mk. I kit. ;)
Thank you Revell-Fan.
No the AT-AT is not very high on my ToDo list.
I have built already two big Star Wars Models, now i need to do something different from Star Wars.
Besides if i decide to build a "Dog" ;) i would try to do the AT-M6 with details.
Maybe the Alien Derelict which is already cut out and ready for gluing ?
