Ok. Not a problem. Since this way works better for you, GO FOR IT! However way you do it, you are still doing a great job!I tried that way with the first one I built.... ended up having to make 2 more exhausts.
I did it this way and it worked better for me. That's just me though.... a lot of things work
better for me in reverse.
Am I just odd..... or are other people like that too.
I did this when I first built the figure... Later I thought that I would have to shorten it more. However, the 1/4" I had already taken out ofThe torso would be easiest to cut down, you could have it slide (top over bottom section) till it fit, and it wouldn't be noticeable.![]()
My printer prints a little darker then the screen shows (I'm ok with that)... and I colored the paper edges with permanent markerBOY, that looks outstanding indeed! It looks as if your colours are even deeper and "thicker" than on our first builds. It looks almost as if you have spray-painted it while keeping the lines intact. The result is awesome!:Bravo::Bravo::Bravo:
