Amorman, thanks for the info on painting.  Any special kind of markers?  Any recommendations?  I have seen Sudsy's BMP in person, and I do like the idea of doing that.
Also, thank you for posting these models, I am having a lot of fun working on it.  This is the beta build, ie. how do I put it together, model.
Putting the main compartment together.
Found a gap, cause 'tab' and adding thickness by laminating and folding.
Removed the offending tab, and now closes better.
First attempt to use UHU, glue, goes on blue, drys clear, for lamination.
Seems to lie flat, looking better!
I removed the tabs, that were laminated and cut around, because when you score and fold, they prevent the sides for sitting correctly under the top.  So, I, the novice, still need something for registration, so I cut new 'tabs' and glued them on where I wanted the sides to attach under the top.  I just glued it up and it looks pretty good.
Need more pictures.....  Have to send them from the tablet.
Scott ;-)  Have fun!
