Star Wars Millenium Falcon from Shunichi Makino
bigpetr
Designer/Master Modeler
Jan 27, 2016
924
1,469
Czech Republic
I just checked texture precision and accuracy against some photo reference of original model. Shunichi Makino did superb job and textures are very accurate and precise. Also, model is in vector format, so you can scale it as you wish without quality loss. Can not wait to put my hands on it.
If my calculations are right, scale is around 1:100
THANK YOU SO MUCH FOR THIS THREAD!!! :)
THANK YOU SHUNICHI FOR MAKING THIS MODEL. I'm so looking forward to it.
I have calculated 1/91, however, that was more a guess than actual maths. ;) I'll have to see if the number he posted was supposed to be the length or the width of the model. Anyway, like you mentioned before, the pattern is a vector graphic, so you can easily resize it without losing quality. WOW, this is an exciting model! :)
Folks, I recommend checking his site on a daily basis in order not to miss an update. ;)
Reactions: bigpetr
If somebody is interested :) I did some comparison with original models and this is what I found:
Original models:
- 5 foot long Millenium Falcon ("5footer") was main model build for Star Wars IV - A New Hope (ANH)
- another smaller 32" long model was build for Star Wars V - Empire Strikes Back (ESB) so they could do more dynamic flying shots. They also added additional two legs to landing gear of 5footer. There were originaly three legs in ANH.
- for Star Wars VII - Force Awakens digital model was created based on original 5 foot model
5footer and 32" are not identical. There are differences in owerall proportions and greebling details. 32" became source for all the models, toys and images.
Paper Model from Shunichi Makino:
Proportion wise the model seems to be close to 5footer. Details and textures are based mainly on 32". On bottom side are boxes for 5 legs landing gear, so this model is ESB Millenium Falcon or ROTJ (Star Wars VI) version. As I wrote earlier, details are precise. Amazing work Shunichi Makino Claphands.
Original models:
That is interesting information indeed. Thank you for sharing it with us.
Just an FYI, There are now 9 download parts available for this model.
The Falcon is nearing completion:
It is way bigger than the original version (left):
Reactions: bigpetr
Yesssssss:).
As Shunichi Makino says in his blog, final version on the right is 33 cm long. So we can safely say, scale is cca 1:105
I will greeble it inside out and outside in:).
Hummmm.... I suggest to enlarge it a bit to ... let's say, 1/72............ ;)
I want to enlarge it to 1/48 scale (and make the saucer round), but I am still considering pros (same scale with my X-wing:)) and cons (size, more greebling = more time to build:().
I already started research for greebling and it is overwhelming. On original model is 2500+ greebles:eek:. Here is video showing unique greebles used on falcon:
:surprise::surprise::surprise:
WOW! That is a SHED LOAD of greebles!!!
