XtrkCAD and crossovers
iis612
Member
Dec 26, 2006
485
52
Chicago Burbs
I am currently working with Xtrk, and I am having some success, but I need help.
I recently switched to Windows Vista, and it disabled the help section for Xtrk.:curse:
How do I add crossovers on a double main line?
I have tried using a turnout and modifying it, but it won't join the running end of the second line with the back of the turnout section.
if you actually have some cross overs or go to your LHS and get all the measurements of the crossover you want ,then go back to xtrk and click 'turnouts' and click on new then go to crossovers,there you can put those measurements to make a cross over.it took me awhile also to figure this out that for some reason xtrk didnt have atlas C83 or crossovers,which is a real pain since my layout has alot of them.anyway hope this helps.
IIs, if you layed out your track seperation using paralell, there should be no problem making a crossover with # 4 or 6 mark three switches. Snap switches won't work
Loren
I ended up joining 2 switches. Thanks for the input.
I am going to add my crossover sections as per Grewsome's advice and redo it.
