I was reading the "Newbie needing information" thread and decided to visit Woodie's Website.
Click here for a link to Garahbara Railway website
Under the Construction section #3 I saw the following.
Wow! That's what I used to do. Instead of using the plastic Atlas slide switches or coughing up the cash for momentary switches for my remote control Atlas Snap Switches.... And I thought that I was the only one.
It wasn't pretty, but it was functional.
When I get to building my new layout, I will employ the same method, but with a little more finesse.
I'm old fashioned (And cheap!
) So I will be sticking with Cab Control for the time being. The layout (HO) will be going in to an eight foot by eight foot space in the corner of the basement and will likely be an "around the wall" set-up.
The idea is to put a diagram of the layout at the control panel with the power packs and throttles. I'll use dpdt switches for the block power. To power the remote control snap switch machines, I will put a small brass nail into each branch of the turnout on the diagram. The tip of the brass nail will have the appropriate lead wire to the remote control snap switch machine soldered to it. A small piece of brass rod soldered to the "hot wire" will act like a little magic wand. All I have to do is touch it to the desired brass nail head to activate the remote control snap switch machine.
Now I just have to figure out a way to convert the Atlas remote control snap switch machines for mounting under the layout. They are really ugly, and I'd like to be able to hide them. I know that Atlas makes under the table remote control snap switch machines, (Did I mention that I'm cheap?
) but I'd rather do the conversion on machines that I already own. Besides, if I am giong to cough up any cash, I would prefer to spend it on nicer looking turnouts like PECO's.
This brings me to a question....
What is the attraction for the Slow-motion machines like the Tortiose? I know that they allow all sorts of fancy wiring options like signal lights and such, but still....
from Woodie's Website
Wiring can be tedious and confusing. Point switches need to be mounted. Nothing wrong with bare wires, and a "hot" wire to switch the turnouts!
Manual Switch Throws
