Need some help please.
I will be using Atlas n scale code 55 track.
I had purchase the MT00310041 (MT1035-10) Barber Roller Bearing Trucks w/short extension (10 pack) , but not from Fifer hobby. To replace my Atlas trucks on some of my Atlas rolling stock. I also purchased a package of the low profile wheels. But once i put the lp wheels onto the trucks, mounted them back on the frames. The wheels do not spin freely at all. They seem to be rubbing against something. I loosen the mounting screw, that did't help. I was thinking about adding some Grease-em (powered graphite lubricant), to see if that helps any.
Maybe someone else had encountered this same problem, to help me out.
Thanks,
CAS
Thanks,
CAS
It will bind things up as quick as it can dry.
