keeping it light
One way to drastically reduce the weight of traditional open frame bench work is to use ripped sections of plywood instead of structural lumber for the pieces, replacing 1 by 4s , for instance with 1/2 inch plywood cut to two or three inches. You could add blocks of wood at the joints , with gorilla glue to take sheet rock crews form both the sides. At the end pieces, that would joint to another section of bench work, you might want to use thicker plywood 3/4 or 1 inch.
I'm not a fan of putting track directly over foam, as I like to have something to work with, if I have to weak the rail, but If you used cookie cutter roadbed, you could have plywood under the track, and you could cut and fit foam elsewhere to keep things light. I have a experimental portable in the narrow gauge section, that foregoes traditional bench work, with plywood glued directly to foam with gorilla glue
http://www.zealotmodels.com/forum/showthread.php?t=172542
This technique is a little heavier than I would like, but it also is looking way better than I like so I'm satisfied.. For a layout with multiple sections, You would have to splice in some kind of a frame in order to fasten the sections together. another low weight option for bench work would be some of the steel framing materials that are available now in place of traditional 2x4 framing. it is counter intuitive, but due to their thin profile they weigh considerably less that the wood they are designed to replace. some hybrid mixture of steel and foam might be a good compromise in the strength vs weight .
Good luck, when you start getting things done please share, so the rest of us can learn from what you do.
Bill Nelson
