A Temp-Low question
TrainClown
861
Saskatchewan, Canada
I bought this stuff at the LHS tonight. It is called Temp-Low and is a low temperature lead casting element. Has anyone used this stuff for casting parts? I would like to cast parts with it. In rubber or plaster. I would appreciate any info you have on the use of this stuff before I go get all silly.
Thanks.
TrainClown
Go to smoothon.com. They have all kinds of casting rubber. Most can handle low temp casting alloys. They have a putty that can be used as a mold once it cures. You might want to check into that stuff. Especially if you are planning on copying some detail parts from the junk box. Just mix, smash around the part, let it cure, then cut the original out. http://www.smooth-on.com/PDF/Poyo%20Putty%20-%20TB.pdf
Ok, maybe not quite that easy.
They have instructions for different molding procedures, so take my simplified explination as a guide to what you are needing to search for.
They do have a material called Sorta-clear that you might also want to check
http://www.smooth-on.com/PDF/Platinum%20Series%20-%20TB.pdf
I think that Jim is right: it's a bismuth alloy and doesn't contain any lead. Never used it, since I use cast lead for car and loco weights.
Back in the 1950's they had an article on making molds out of cardboard to make molds for passenger car sides and other flat pieces, George Allen's old Tuxedo Junction series. It is also available more cheaply and in larger quantities from industrial suppliers.
http://www.mcmaster.com/
Just a thought
Harold
