TOS Enterprise Bridge build
Ron Caudillo
Creative Advisory Consultant
389
315
Davenport, Iowa
Hi all,
I recently built my TOS Enterprise bridge model for my nephew and am posting the build process that I used.
I can definitely tell that my building is suffering due to gradually weakening eyesight (old timers). Had to use a magnifier on a lot of it. Man the camera REALLY shows all flaws that can't really be seen on the actual model! I found a few problems in the model (an errant line across one of the stations, and I need to make the outer wrap a bit longer to allow it to fit better) so you may want to let me upload the revision before downloading it.
First some preliminary stuff.
000: I bought these watercolor pencils just recently and wanted to try them out for edge coloring. They have soft leads and do not crush the edges (but you still have to be careful and move across the lead so you don't "cut" into the lead and create a groove. I also used felt markers for this project. A black and red are pretty essential for the railings, step sides, and console. You can get away with a light blue highlighter on the chairs.
001: Use a very sharp blade and cut an "X" in the small white circle for the insertion of the station chair posts later in the build. There are two intersecting red lines to use as a cutting guide.
002: Note the slight indent on the raised deck (part 3). This is to allow the insertion of optional viewer screens to fit your mood and the model's appearance.
003: On the raised deck (part 3) there are narrow white lines radiating across the black inner ring. This is used to help locate the railing supports (parts 23) later in the build. There are also white lines (picture not shown, sorry) on the two deck inside edges (parts 1 and 2) as well as on the sunken deck (part 4), the step sides (parts 14), and the stair sides (parts 17). These are used to locate the parts to form the assemblies and glue to the raised/sunken deck assembly.
004: Note that on the deck inside edges (parts 1 and 2) the end tabs are shorter than the height of the part. This to to allow for clearance of the upper tabs on those parts.
Ok, enough of this, on to the build!
Ron Caudillo
The build begins...
ALWAYS TEST FIT PARTS SO YOU KNOW HOW THEY WILL FIT PROPERLY.
005: Form the deck inside edges (parts 1 and 2), bending the top tabs BACK. Glue one of these one tab at a time to the inside cutout of the raised deck (part 3), making sure you have the top of the inside edges EVEN with the cutout of the raised deck. The raised deck should not overhang the the inside edges. If you start with part 1 and glue the long part under the edge for the main viewer and work your way around, you will not mis-align it.
006: The completed first steps.
007: Fold up the sides of the sunken deck (part 4) and join them together with the joining tabs to the outside. Fold down and INWARD all of the top tabs.
008: Turn everything upside down and test fit the raised and sunken decks (if you turn them right side up, you can see what the final result will be, but they will not stay together. You will note that the top tabs of the sunken deck will fit EXACTLY inside of the raised deck inside overhang. Once you understand how they should fit, separate and glue all of the top tabs at the same time and reassemble. You will not be able to press the tabs of the sunken deck to the underside of the raised deck , but with light pressure, I have never had a problem getting a good bond.
009: Turn over and check the appearance of the two joined decks. The overhang should be evenly distributed around the inside edges.
010: Place a moderate flat weight on the assembly to help keep it flat while it dries.
Ron Caudillo
Next- The Command pedestal/platform and the Navigator/Helmsman console base.
011: Be sure to cut the red "X" in the white circles for the chair posts of the pedestal (part 6). Assemble the pedestal and glue into place, making sure it is set back against the inside vertical wall of the sunken deck and apply glue to the bottom, rear, and the the top of the support. Be sure all of the white of the sunken deck is covered. Fold in half and glue the platform support (part 7) onto the pedestal where indicated. Allow this to dry a bit.
Assemble the chair platform (part 8). Form the column into a cylinder and join together. Note that there is a slight dip in the top of the column, this goes to the rear when you edge glue the flat bottom of the column to the top of the platform, making sure to cover all of the white circle.
014a: Note that there are 5 fold lines that fold UP. Three of them are pointed out at the top by the knife blade and the other two are on the lower area.
014b: Fold on all of the lines and start wrapping/gluing the side.
014c and 014d: Continue on the side, matching up the top of the side with the folded up part of the top and glue in place.
014e: Continue around. I have drawn lines on this photo because it was hard to see the tabs/edges. The base is turned upside so you can see that the tab that joins the top of the front side is folded inward and glued to the underside of the top. The other side has been matched up and gued as well.
Next- The Navigator/Helmsman console top.
016a: Note that five of the fold lines are not very visible for the console front and sides and for the bottom of the sides that will fold up. Be sure to score them.
016b: Fold down the front and two sides and glue the side seams.
016c: Turn the console top over and fold in the bottom of the sides.
016e: Glue the insides in place.
017: The console top.
018: When assembling the console front piece (part 12), notice that there is a small protrusion on the front of the side at the bottom. This will overhang the command pedestal (part 6).
019: When I build the Red Alert indicator (part 13), I don't cut it off completely so that I hold onto something and can fold in the sides and edge glue together. (This also helps to color the edges!) When it is dry, I cut it off and then attach it to the top of the console.
021 and 022: glue the parts of the console together as shown.
023: Glue the completed assembly to the command pedestal, making sure to completely cover the white area.
Ron Caudillo
Next- the Captain's chair (Kirk's throne...lol)
024: The three parts of the Captain's chair after assembling each of them. Notice that on part 20, the tops of the arms are not folded and glued down yet. Notice also that on part 21 that the black triangles are not folded over and glued yet either.
025: Parts 21 and 22 glued together first to form the seat. The black triangles of part 21 is now folded and glued down.
026 and 27: Glue the seat assembly down onto part 20.
028: Glue the tops of the seat arms down. The brown "wooden" portions that point back are slightly bent up to rest on the tops of the black triangles and glued down and to the sides of the seat back.
029: Apply glue to the top of the Commander's chair column (part 9) and press the chair into place.
Ron Caudillo
Next- The steps (hope you have good eyes, a steady hand, and some good tweezers).
030a: Note there will be "notches" cut out (later) on the steps.
030b: Cut out the parts for the step assemblies (two of parts 14, one of part 15, and one of 16 for each of the side step assemblies. Two of parts 17, one of part 18, and one of part 19 for the step assembly under the main viewer. Fold each part in half and glue together. You may need to place weights on them to ensure they remain completely flat as the glue dries.
031: Cut out the steps and sides. Cut out the "notches" of the steps. This only needs to be as wide as the double thickness of the sides.
032: The parts of one of the side step assemblies. The parts for the steps under the main viewer are similar. Notice that the UPPER step is LARGER. The white lines on the side show where the steps are to be glued. Start with the side step assemblies to follow the photos then use similar procedures for the step assembly under the main viewer.
033, 034, 035, and 036a: Glue the step steps to the sides by inserting the side into the step notches. Check these photos for proper alignment of the parts. The steps should be parallel to each other and to the bottom of the sides. I find that if you let the glue set (but still remain "slightly" pliable will help you to glue the assembly into place and get the alignment correct. This way you can "adjust" the joined parts as required to make them look correct when glued into place.
036b: Glue the steps into place. The bottoms of the sides should be on the white lines of the sunken deck and the back of the steps should go over the white lines of the raised deck overhang.
037: All three step assemblies in place.
Ron Caudillo
Next- The hand rails (not as bad as the steps, but can be tricky). Then the Turbolift doors, MUCH easier!
038a: Cut out the 4 small white rectangles on each of the four handrails. It is better to make them longer rather than shorter as they are used to help locate the railing supports. All of the rails are identical as are all of the railing supports.
038b: As you did for the steps, fold the parts in half and glue together. Place weights on them to ensure they dry completely flat. Then cut them all out. Be careful cutting out the railing supports, especially at the top (to make sure it is not too wide) and at the bottom to assure a 90 degree angle.
039: Working from the underside of the railings, glue each of the railing supports into the cutout notches. Make SURE the railing supports are oriented the correct way! I find that if you let the glue set (but still remain "slightly" pliable will help you to glue the assembly into place and get the alignment correct. This way you can "adjust" the joined parts as required to make them look correct when glued into place. Glue each of the rail assemblies into place onto the top and sides of the raised deck overhang where the white lines on them show where they go.
040: All rail assemblies in place. You can breath now, the worst is over!
041 and 042: Nothing special about the turbolift area except note that the vertical folds are in teh middle of the vertical black lines and to fold in the proper direction around the top and bottom faces.
Ron Caudillo
This model is a Gem, and to have you do a build thread for it, well, that makes it a "Sticky". :)
Reactions: Ron Caudillo
Hi all,
Your weakening eyes are way better then mine, because your camera showed me no flaws in your build!
I was totally surprised to see Ron Caudillo building his TOS Bridge! I have been watching his build since the first post in amazement. As Tonino said "it's a rare opportunity" to watch a designer of such a great model building his own model. I will keep watching till the end.
Thanks all for the nice comments! I have the other pictures ready to continue, just need time to continue, just went on vacation.
