Very nice greebling there! Patience and dedication, that's what it's all about... Nice work!![]()
Dan,
Hey thanks!
Sky Seeker
:tank:
This looks really good. I like detail and greebles that you are putting into this model!
Rhaven,
Thanks! The detailing is quite slow. The smallest pieces take the longest time sometimes to cut and edge color. The engines have the most detail on everything on the ship. Still trying to figure out an efficient way to cut the circular sections. Guess I have to find some hole punchers. At the rate I've been going, I might have this done by the time my oldest gets to college.
Sky Seeker
:tank:
Dealing with painting the edges of small parts, use fine point tweezers.
If you can not get a hole punch, use a fine tip knife and a steady hand.
I have faith that you will get it done in a reasonable time. I am closely following this thread.
Rhaven,
Hey thanks for your guidance there master builder and your confidence!For this model I've found a freshly sharpened pencil and fine tip black marker work well. The pencil helps to removed some of the glare that the bottom laminated piece creates when the detail piece is laminated with additional cardstock to create a raised effect. This is about the best way found so far to give a black, gray, and white model some detail other than just printing the features.
If you have any other ideas please share them.
Sky Seeker
:tank:
I (myself) use watercolour paints and a "dry brush" technique. (*NOTE* They have to be TRUE water colour paints for this particular technique to work properly)
I start out with mixing the colours that I need. I then allow the paint to dry into a "cake". Once I have the dry paint "cakes", I will dip the paint brush in water and re-activate the paint. I will only get a very small amount of paint on the brush. Then I very lightly paint the edges (BEFORE I glue the parts together).
Once properly mastered, this technique will give you excellent results (even with very thin paper, like printer paper).
Would that work with paints like Delta Creamcoat or Apple Barrel? They are really thick to begin with.
They're craft paints. Pretty thick, (like wall paint or runny pudding) but thin easily enough with water. I started using them when I was making wargames terrain on a regular basis. I use them to edge my models now, with a small flat brush and drybrushing the edges. They have a hard time covering up sharpie pens, however.
You shouldn't have white lines. This is not taking time to mate parts properly. The other main cause of this is using tabs, which is the worse thing that has ever hit paper modeling. How can you line up to edges when they are not on the same plane.. When you cut off the tab, you can then glue it, or another piece of paper, on the backside, and then you bring up the part to mate, it will be on the same plane, and you still still have a surface to glue onto. Tabs ruin models. It is the major cause of white lines showing.
I am of the opinion now that the engines are fine the way they are. This may be because you have enhanced (gettin' tired of the word greeble) too such a high degree, you eyes are no longer drawn instantly to the rear. The phenomena of your eyes going from front to the "Rear" is a problem with advertising .
See what I mean.
This bicycle company didn't sell one bike, if you look hard, you can see it why it failed. They sold millions of robots though.
I used both techniques on the Omega Destroyer and found that when I made the tabs separate from the main model body on the underside of the surface it joined smoother than the tab method. Although as a reference for new beginners it works well to start. As one gets more advanced and comfortable with paper modeling in general it is sort of akin to training wheels on a bike (a least that's what I think).
